Re: Farmall 1206 - diesel in oil
Posted by Kevin Sweet on May 09, 2011 at 19:19:07 from (67.140.167.26):
In Reply to: Re: Farmall 1206 - diesel in oil posted by Weldon K on May 09, 2011 at 18:54:18:
When I took the pump off the first time, I did not notice any seals on the shaft. I did not pull the injector pump drive shaft out of the housing on the tractor. Where do the seals go? I am sure I made a mistake somewhere. I ran tractor 1 1/2 hours today and the oil level rose about 1/4" on the dip stick. Could timing cause this? I am really behind cutting hay and I need to get this resolved.Thanks for any help you can provide - Kevin
