Re: 706 engines
Posted by Country Nate on May 10, 2011 at 07:35:33 from (206.224.20.9):
In Reply to: Re: 706 engines posted by The tractor vet on May 10, 2011 at 07:25:39:
Vet,
I have been reading your posts for years and I have learned alot from you about the old gas engines from you. I don't have an IH gasser but I do have an old Case 730 gas (about 58 hp) and I did some of the things you suggested and it really helped. Especially timing it correctly and running the 93 octane. Yea, it will use a bit more fuel than my diesels but at the price you can pick these old gassers up who cares. Even if I use $200 bucks a year more in fuel the tractor is paid for!
I live over in NW PA and I hope to meet you someday.
Thanks again, Country Nate
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
