Generator tag numbers?
Posted by dieselmech86 on May 10, 2011 at 17:53:04 from (68.184.249.75):
I have a 62 Farmall 504 I just got a rebuilt generator for (12v) It didn't come with a tag and I would like to put one on as I am restoring this tractor. I have the correct (red) tag and rivets to install, but I don't know the format of the part number and serial number (if there is one).
What is the part number for the 12 volt generator used on the 504 diesels? What was the format for the serial number for that era generator, and what number would put it at that general date? Tractor I believe was made in May 1962.
Thanks for the help.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
