Re: Generator tag numbers?
Posted by Nebraska Cowman on May 10, 2011 at 18:48:12 from (66.252.115.12):
In Reply to: Generator tag numbers? posted by dieselmech86 on May 10, 2011 at 17:53:04:
I would not just pick a number out of the blue. The only way I would put a serial number on one is if I had an original tag.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
