Re: 706 engines
Posted by Country Nate on May 11, 2011 at 07:14:48 from (206.224.20.9):
In Reply to: Re: 706 engines posted by The tractor vet on May 10, 2011 at 19:28:01:
Thanks for the info vet, I appreciate it.
My uncle ran a case 800 gas tractor for years on the 87 and yes it worked, BUT when you went to shut it off, it keept going and going and going. I'm no tractor expert, but that ain't right boys. All you have to do is sit on my 730 Case with 87 vs 93. If you pay attention, you can definetly tell the difference. That's all I need to know, it's 93 for me.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
