Re: Power adjust rim color
Posted by rustyfarmall on May 13, 2011 at 06:16:50 from (216.248.71.224):
In Reply to: Power adjust rim color posted by rhtx55 on May 12, 2011 at 20:31:00:
I'm not sure that is correct. I have cleaned up more than a few rear tractor rims that had aluminum paint on the INSIDE of the rim, and using a cup brush on an angle grinder to take it down to bare metal revealed NO indication of galvanizing on either the inside or the outside of the rim.
Not trying to start an argument. I am only stating what I have found.
