Re: M stumbles and chugs until under load
Posted by Wilamayb on May 14, 2011 at 13:07:50 from (71.15.151.11):
In Reply to: M stumbles and chugs until under load posted by Wilamayb on May 14, 2011 at 10:09:34:
I have adjusted the idle screw for best idle qualities and also adjusted the load needle to prevent sputtering but to also eliminate black smoke. It runs fine under load...
I did check for vaccuum leaks with an aerosol can of brake cleaner. It appears to have none. My symptoms do scream vaccuum leak which is why I checked it first thing.
Still no comment on the Threads per inch of the tappet adjustments?
