Posted by Wilamayb on May 14, 2011 at 10:09:34 from (71.15.151.11):
I'm working on an M for a friend that said he was sick of looking at it. Since he was so disgusted with it not running he pushed it outside the barn about 2 years ago where it endured the elements during that time.
His problem was that it would sputter anytime the throttle was opened up or it was under load. I found that problem. It was mud dobber nests in the air cleaner.
The tractor had all the issues of sitting outside for 2 years....
I had the carburetor cleaned and regasketed by Popin John in Kerhonkson, NY who has always done EXCELLENT work on my Deere magnetos and carburetors so I trust that it is done correctly. He also rebushed the distributor and tested it afterwards.
It has electronic ignition and produces a very very hot spark all the way to the new Autolite plugs so I'm feeling like that is not an issue. Run timing is set to 20 degrees BTDC by timing light.
The problem.....It chugs while idleing and also under full speed if not under load. It actually chugs even under partial load. It really doesnt clear up until under full load.
I suspect tappet clearance but the rocker arms are so cupped from wear that feeler gauge adjustment is out of the question.
I've pondered adjusting the tappets by using the adjusting screws as the gauge but I dont know TPI's to be able to convert rounds of turning into a measurement. Does anyone know that info?
Any suggestions? I've tried adjusting the idle screw on the carb in both directions and it is effective in both directions but it does not ever allow it to run smooth.
Any thoughts or comments? I'm a two cylinder guy and am open to any IH suggestions..
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
