The cap or cup over end of valve is pushed down with the decompression mechanism and is under neath the rocker arm shaft. If you wanted to take the cup off you would have to remove whole rocker arm assembly. They are a regular shaped valve but very small, and open into the spark plug, gasoline side combustion chamber therefore lowering the compression ratio for starting on gas. Usually you can get them to move down a little but getting them to move back up is a little harder. You might be lucky and be able to do so from spark plug hole but those two center ones are really hard to get at. May have to take manifold off. They have to move totally free and also not leak when seated. They are very prone to warping when not cooled on their seats. That is why I suggest checking by cranking with spark plugs removed with lever in diesel position as first of all if stuck open you will have total compression leaking out through the plug hole and if they are closed but leaking you will have some leaking. A slight leak can be tollerated .There are other ways to also check them but this is simplest.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
