Posted by old on May 14, 2011 at 16:16:52 from (209.86.226.59):
In Reply to: cub won.t stat posted by mike in ohio on May 14, 2011 at 15:32:12:
I almost bet if you trace the wire from the V.R. Ya there should be another wire going there and the switch hook up was done there just because it was an easy place to hook to. So what I am saying is that place on the V.R. most likely should be hot at all times and for some reason it is not as in a broken wire or missing wire
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
