Posted by mike in ohio on May 14, 2011 at 15:32:12 from (75.185.187.71):
1948 farmall cub won"t start. No power to the coil. The switch has one wire from the voltage regulater and one to the coil, when I try to start there is no spark. If I jump a wire from the battery to the - side of the coil(positive ground) it starts and runs fine. I cleaned up the contact on the voltage regulater now sometimes I have power to the switch sometimes not. My first thought was to run a wire straight from the batt to the switch to bypass the vr. When I do this it starts easily. It was running fine till this week then this started. Should I replace the voltage regulator or am I missing something?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
