Re: cub won.t stat
Posted by Janicholson on May 14, 2011 at 17:49:49 from (74.93.0.174):
In Reply to: cub won.t stat posted by mike in ohio on May 14, 2011 at 15:32:12:
I will ad to Old's info that the switches go bad regularly (after 50+years) so jump the switch to see if it is intermittant. The L terminal on the Regulator (and the Bat terminal on the Regulator as well) are hot all the time. Jim
