Re: M stumbles and chugs until under load
Posted by redgems on May 14, 2011 at 22:27:10 from (173.150.182.227):
In Reply to: M stumbles and chugs until under load posted by Wilamayb on May 14, 2011 at 10:09:34:
I had what sounds like same problem on my SMTA a few mounths back. Did all the things mentioned here to no avail.plus rebuilt dist,several new caps, several sets of wires, etc,etc. Then out of shear desperation I bought set of ss center, puller wires and a 55000 volt coil from dennys carb and autolite 3116 plugs; problem solved with little tweaking of timing. I am not sure if this right way to set timing but I set tractor at medium trottle and move dist slowly until I find the sweet spot and its timed. Tony
