Farmall 140 Touch Control Won't Lift
Posted by SouthernFarmall on May 15, 2011 at 13:26:18 from (76.4.24.140):
I have a disc hooked up to the 140 right now. When I flip the lever to lift it, the rockshaft moves slightly and the engine stays under load. The disc is never lifted more than an inch or two. The lift worked fine with the disc on Friday. There is no problem with the front lift; only the rear lift will not work. Currently there is a leak underneath to hydraulic reservoir, and I am planning to get that fixed.
Does anybody have any idea as to what could be causing this malfunction? SF
