Re: Farmall 140 Touch Control Won't Lift
Posted by El Toro on May 15, 2011 at 14:33:31 from (108.15.86.54):
In Reply to: Farmall 140 Touch Control Won't Lift posted by SouthernFarmall on May 15, 2011 at 13:26:18:
I would check the oil level in the reservoir as you may be low from the leaking. I would install a gauge and see what your pressure is. Your manual should have the pressure. I see on the Cub, C, Super A and Super C should be around 1100-to 1500 psi. Hal
