Farmall A Battery Box
Posted by Stevie J. Mote on May 16, 2011 at 18:24:39 from (75.215.244.125):
Hello. I just got me a new battery box for my 1945 Farmall A. Saw the two tabs with bolts for the side, no problem. Also tab on the rear of the box has a tapped hole. The front of the box also has a tab but the frame is not threaded to secure it. Can you all help me out on this. THANKS
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
