Re: Farmall A Battery Box
Posted by gene bender on May 16, 2011 at 19:34:50 from (207.177.56.53):
In Reply to: Farmall A Battery Box posted by Stevie J. Mote on May 16, 2011 at 18:24:39:
The battery boxes for the A dont have any tapped holes. There is two tabs on the back where bolts hold it to the bell housing and two tabs underneath where two bolts fasten on the side of the bell housing no threaded holes anywhere each end of the box at the top has a bracket to hold the t-shaped fasteners that hold the lid.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
