Re: external resistor
Posted by John M on May 18, 2011 at 03:11:08 from (67.231.169.173):
In Reply to: Re: external resistor posted by Bob on May 17, 2011 at 21:45:02:
Bob, Im not taking about the coil, not do I think the OP is either. He said 12 volt at the resistor on one side, 6 volt on the other. (I can honesty say, Ive never checked the voltage on the "out" side of a resistor, other than to see if it was there, IE my meter moved, so 6 or so volts on that side may be off) BUT what Im saying is you have 12 volts at the battery, to the switch to the coil NO MATTER if the points are open or closed. Putting a resister in line doesnt change that 12 volts, take the wire off, you still have 12 volts to it, so why does it matter it the points are open or closed, as is mentioned by others.
