Posted by David G on May 21, 2011 at 17:28:31 from (75.245.18.222):
I had the fan off my H, the water pump is now leaking slowly. It did not leak before. I did not put a lot of tension on the springs when I put it back on.
Is there tension that needs to be on the pump with the springs to prevent it from leaking, or do I need to replace it?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
