Re: H Water Pump leaking
Posted by Nebraska Cowman on May 21, 2011 at 18:26:08 from (66.252.115.12):
In Reply to: H Water Pump leaking posted by David G on May 21, 2011 at 17:28:31:
That's what the springs are for. Kinda. The springs hold the impeller forward in the housing. The seal is around the shaft. Pulling on it harder may get it back where it was running before... But I suspect you've disturbed the seal allowing it to seep. There is a packing nut you need to tighten just a little. That may work. But if it has not been disturbed for centuries the sealing material may be so hard you can't compress it any more.
