I recommend that you install the engine, be sure that the engine, trans, hydraulic oils are full. When filling the coolant, if the temp sender is on top of the head, let it loose, allowing the air to bleed out, then tighten it. I would remove the spark plugs, put some light oil in each cylinder, then spin the engine to raise the oil pressure. Re-install the spark plugs, and start it up. Let it run above idle speed and look for any problems.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
