Re: farmall M charging and discharging????
Posted by The Red on August 02, 2000 at 04:11:58 from (12.75.196.126):
In Reply to: farmall M charging and discharging???? posted by al on August 01, 2000 at 16:27:12:
Al remove the cover from the voltage regulator. I bet the points are opening up too early as you decrease the engine RPM. You can make an adjustment on the spring tension so you charge at lower RPMs. Make only a very minor adjustment or the points might stay closed after you shut down resulting in a battery being drained very quickly.
Post A Followup
: Re: Re: farmall M charging and discharging????
