Re: 340 bad TA/clutch
Posted by Janicholson on May 25, 2011 at 14:14:45 from (67.72.98.45):
In Reply to: 340 bad TA/clutch posted by Gene F on May 25, 2011 at 12:26:59:
Try adjusting the TA clutch so that it starts releasing just as the main clutch is released.
Adjust the main clutch so the pedal moves about 1 inch at the pedal freeplay.
Then put it is third or 4th and just see where the tractor starts to pull as you let up on the clutch.
Measure this amount (safely).
Set the Ta clutch so its T.O bearing is just touching the fingers at this point. Jim
