Re: 340 bad TA/clutch
Posted by Janicholson on May 25, 2011 at 17:41:21 from (67.72.98.45):
In Reply to: Re: 340 bad TA/clutch posted by Janicholson on May 25, 2011 at 14:14:45:
The primary issue with book adjustment is wear on pins and clevises. The trick is to adjust to compensate for the wear. If yours is holding in TA, and shifting to direct works, I would sure adjust before considering a delete. There might be a source for the needed components, but it is complex due to the IPTO drive system. Kevin Meier on this board has parts. Jim
