Re: Farmall Oil Guage readings
Posted by Owen Aaland on May 26, 2011 at 17:15:23 from (216.47.32.42):
In Reply to: Farmall Oil Guage readings posted by Yooper Farmall on May 26, 2011 at 11:17:17:
Hs, Ms and 9 series use an 80 lb gauge. As, Bs and all others with that style engine (113, 123, 135, 146, and 153) up through the 340 use a 45 lb gauge. Engines that use the 45 lb gauge have an oil pump with an aluminum bottom cover that often warps and has gasket failures. The larger engines that use the 80 lb gauge have a cast iron bottom cover on the oil pump.
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
