Posted by Brownie 450 on May 29, 2011 at 19:22:35 from (66.43.241.198):
In Reply to: 884 not charging posted by GRB54 on May 29, 2011 at 06:12:27:
Assuming a Delco alternator with 3 wires. Check for 12-volts [battery voltage] at #2 terminal. Check for~ 9-10 volts at #1 terminal with ign on. Use an analog meter if possible. If no reading at #1, check for open circuit from switch through lite to #1 terminal. Try shorting between large terminal on rear of alt. & #1 momentarily. If voltage picks up, alt. is good yet. If voltage remains low, check diode trio, rectifier bank, or brushes.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
