Re: F-30 cooling
Posted by Nebraska Cowman on May 31, 2011 at 16:54:40 from (66.252.115.12):
In Reply to: Re: F-30 cooling posted by F-Dean on May 31, 2011 at 06:42:50:
I guess I need help understanding this. If you don't need to block the bypass when the engine is hot and the thermostat is open, why do you need to block it when the thermostat is removed?
