Re: H Generator - Works with F term grounded to battery?
Posted by teddy52food on May 31, 2011 at 17:19:58 from (68.169.216.43):
In Reply to: H Generator - Works with F term grounded to battery? posted by Dan G on May 31, 2011 at 15:42:14:
Try putting a good ground wire on the reg. base. It won't work if it isn't grounding.
