Posted by Dan G on May 31, 2011 at 15:42:14 from (208.111.228.135):
Ok, I"ve used John T"s diagnosis and it my H passed all the tests, but still wouldn"t generate DC. Replaced all wires (one at a time!) took apart generator and put back together. Ammeter definately works, I went thru his whole checklist. Motor test on GEN worked too...went back over it and I missed step 6... So I grounded the F terminal (to battery ground) on the GEN and jumped the BAT and GEN terms on the regulator and instant + volts on the ammeter. I shut it off, and restarted and as long as that grounded wire is on the F term it generates fine. What"s wrong? I"ve replaced almost everything on this tractor once already and I"d rather replace/repair the right faulty part.
BTW, GEN was professionally rebuilt 1.5 years ago, battery is 3 months old, and regulator is about 2 years old.
It"s a 6volt positive ground system without Cutout relay, (4 term regulator (BAT, GEN, F, L)
Can I just leave the F term grounded? Something is telling me no.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
