Re: H Generator - Works with F term grounded to battery?
Posted by FarmallJon on May 31, 2011 at 19:13:00 from (72.224.243.66):
In Reply to: Re: H Generator - Works with F term grounded to battery? posted by John T on May 31, 2011 at 17:40:32:
My '49 H with magneto ignition needs to have it's charging system diagnosed and fixed. John T., do you have a diagnostic procedure that Dan used? When I got my H, it had the four position headlight switch, and a genny with a voltage regulator. I'm told that if it has a four position switch, it did not use a voltage regulator? it just either charged on 'High" or "low" depending on the selected switch position? I'd rather have a voltage regulator, and not worry about the switch position.
