Jon, My standard generic troubleshooting procdedure is linked below, its NOT perfect or all inclusive but its a start. My friend Bob M has a good flow chart which also helps.
The older systems used a Cutout Relay (BAT and GEN/ARM Terminals) and the Gennys FLD wired to the LHBD light switch which could be set for Low or High charge. The newer used a full fledged 3 or 4 terminal Voltage Regulator where the Gennys FLD wired to the VR and NOT and low high charge switch for automatically regulating the rate of charge. (LHBD can still be used to turn lights to Bright or Dim) Its possible to convert from a cutout relay and LHBD system to a VR by wiring the VR correctly
BAT on VR to load (NOT battery/starter) side of ammeter, same as wire from BAT on cutout up to ammeter before.
GEN/ARM on VR to gennys ARM post
FLD on VR to gennys FLD post AND NOT TO LHBD SWITCH
and NOT use the gennys FLD wired to the switch but VR instead.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
