Re: farmall super a battery
Posted by Janicholson on June 01, 2011 at 05:32:10 from (64.61.211.231):
In Reply to: Re: farmall super a battery posted by pittsk on June 01, 2011 at 04:13:24:
The least expense, and best approach would be to make the following changes. With the battery not connected.
1}Remove the alternator and replace it with a 10SI rebuild negative ground from the parts store of your choice. (Not a one wire setup, but a standard 10SI.)
2}Change the wires on the amp meter from one side to the other.
3}Make sure the diode in the #1 Alt lead is placed such that the index band (marking on the diode) is toward the alternator, and the other end attaches to ignition source. Check the diode to assure it is passing current one way and not the other. (Ohm meter near zero one direction, and near infinity the other.)
4}attach a short wire from the #2 terminal to the out put stud of the Alt. (senses system voltage)
5}Switch the coil so that the Negative small terminal is attached to the distributor lead, and the Positive is attached to the ignition ballast resistor.
6}Reinstall the battery with negative ground.
Run the tractor!
Jim
