Re: Cub Fires on Exhaust Stroke
Posted by Janicholson on June 01, 2011 at 06:19:17 from (67.72.98.45):
In Reply to: Cub Fires on Exhaust Stroke posted by equeen on June 01, 2011 at 06:12:20:
It is easy to get the distributor (or mag) in 180 degrees out of time.
To assess the situation, move all the wires two positions ahead. this will fire the plugs on compression.
If it works, I would retime it to have the wires in the correct location for future owners or to match factory practice.
2-1
4-3
is the way they should look from the factory from the rear of the tractor.
3-4
1-2
Is the work around to see if it is that problem.
Jim
