Cub Fires on Exhaust Stroke
Posted by equeen on June 01, 2011 at 06:12:20 from (209.102.248.55):
third party image
Okay, men, I'm stuck again. Please help.
'50 Cub engine has been rebuilt; new points, fire to plugs in order: 1-3-4-2.
Fire seems to be on exhaust stroke as fire is seen in manifold after I put fuel into any cylinder, install plug, then attempt to start.
Hopefully a couple of photos are attached to help you set me straight. Thanks.
