Re: Farmall A stops running
Posted by Red Dave on June 01, 2011 at 16:33:12 from (98.235.13.108):
In Reply to: Re: Farmall A stops running posted by Todd Heck on June 01, 2011 at 16:22:00:
If you have a magneto, your coil is not oil cooled. A battery ignition coil can be oil filled however.
I would check to see if it might be a fuel problem. When it quits, take off the gas cap and see if it will start again. Sometimes the vent holes in the cap get plugged and the vacuum starves the carburetor for fuel.
