Hi, your problem sort of indicates the same type as I had a while back. Take the gas line off the connection at bottom of gas tank and push a piece of wire up through the small fitting into the tank.Mine was clogged in that area with what looked to be old leaves. Cheers, Murray///Post back when you find your problem.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
