Re: Cub Fires on Exhaust Stroke
Posted by equeen on June 01, 2011 at 17:55:42 from (209.102.248.55):
In Reply to: Re: Cub Fires on Exhaust Stroke posted by oldtanker on June 01, 2011 at 16:32:24:
The timing gears were not tinkered with by the repair shop or by me. (Oops, maybe I need to check with the shop.)
Rick, what you are describing is just what I did originally.
My carb was out for rebuild, thus I poured a cap of gas into the cylinder. My new manifold had not arrived, thus I was able to see fire "belch" from the manifold w/no pipe. I did this three times, twice on cyl 4 and once on cyl 1. There was ignition and fire in the correct cylinders - just seemed to be at the wrong time - with exhaust valve open????
Hoping to have my carb back tomorrow. Will be better opportunity to really test it. Though I don't like fire in the manifold with gas "nearby".
Going back out to the shop and tinker some more now that the sun is down.
Thanks.
