Re: Cub Fires on Exhaust Stroke
Posted by oldtanker on June 01, 2011 at 16:32:24 from (66.228.255.223):
In Reply to: Cub Fires on Exhaust Stroke posted by equeen on June 01, 2011 at 15:54:07:
Just fer yer general knowledge electricty travels through wire at the speed of light. That's why when you flip a light switch you don't notice any delay in the light coming on.
1. Are you sure that the timing gears were all correvtly installed and timed?
2. Get it to TDC on #1 with both valves closed.
3. Take of the distrubuter cap.
4. install distrubuter with the rotor button pointing to the spot where it would be with the cap on pointing at the #1 terminal.
5. Make double sure the wires are correctly installed and try to start.
Rick
