If the pencil is on the piston it will move up and down with the stroke. (I think you have the valves closed, and the mark on TDC now, so all is well. If this continues to put fire out the exhaust, there may be a valve adjustment issue. A compression check would confirm poor valve seating. If all else fails go there. Jim
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
