Re: F-12 update....new rims!!!
Posted by Old-F20 on June 02, 2011 at 15:53:49 from (71.7.102.46):
In Reply to: F-12 update....new rims!!! posted by Seth Boyer on June 01, 2011 at 17:24:28:
minus the case eagle inthe cap, they look exaclty like a set of wheels i had on a wagon, and a #76 combine. problem with them is they have no taper bearings in them. they simply slide over a solid shaft and have a castle nut on the end to hold them on. lube by on zerk. i sure wouldnt put those things on a tractor i was gonna drive around
