Posted by rustyfarmall on June 05, 2011 at 06:23:01 from (216.248.71.224):
In Reply to: Famrall M Carburetor posted by 39MPuller on June 04, 2011 at 15:15:22:
I've rebuilt a bunch of those carbs and never seen like you describe, but that doesn't mean yours isn't that way. I think that pin is pressed in, or driven in, however you want to describe it. Probably could grab the hot wrench, heat the pin and the area around it, let it cool a bit and then grab the pin with a pair of vice grips and pull it out. I don't know for sure if that trick will work 'cause I've never tried it. I may go to the shop later, grab a carb top that is beyond saving and experiment a bit.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
