Re: Farmall H M Starter Switches
Posted by davediehl@hotmail.com on June 07, 2011 at 17:34:25 from (209.45.205.13):
In Reply to: Farmall H M Starter Switches posted by K-Mo on June 07, 2011 at 16:53:57:
I replaced my H switch with a Rural King unit. The original (and I think it was THE original) was getting to the point it would crank slow. There was no heat on the outside of the shell, but the contacts inside were pitted and corroded. If you have heat involved, it means there is resistance. This could be as simple as a loose or bad connection on the cable or an internal problem.
