Re: Farmall H Belly Pump and Break-aways?
Posted by Farmer Bob on August 04, 2000 at 23:08:03 from (208.49.9.205):
In Reply to: Farmall H Belly Pump and Break-aways? posted by mark on August 04, 2000 at 22:50:13:
Mark, You should have a sleeve with a cotter pin at each end of the coupling shaft. Once the lift-all is installed just slide the sleeve toward the center of the coupling shaft, install the coupling and slide the sleeves out towards each end of the coupler. Then install the cotter pins.
As far as the hose shield, there is an after-market shield available that bolts down to the right side of the seat bracket into the deck cover. The shield covers the two hoses (One on top the other) right next to the seat mounting bracket. I got mine from my local Case-IH dealer for around $35.//FB
Post A Followup
: Re: Re: Farmall H Belly Pump and Break-aways?
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
