Re: Re: Farmall H Belly Pump and Break-aways?
Posted by mark on August 06, 2000 at 08:49:32 from (206.172.66.129):
In Reply to: Re: Farmall H Belly Pump and Break-aways? posted by Farmer Bob on August 04, 2000 at 23:08:03:
Thanks FB! At least that gets me started! That I hope to handle!
However, I was also wondering if this belly pump will run a set of remotes on the H? See if I can sorta clarify that... in the operators manual, there shows photos of a "remote control valve assembly" (pgs 18-19)... I do not have this! Can my "basic" bellypump, without this remote assembly, be rigged up to operate a set of hydraulics or remotes at the rear of the tractor?
I warned you that there would be more questions!
Thanks again!
Post A Followup
: Re: Re: Re: Farmall H Belly Pump and Break-aways?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
