THe levers at the control quadrant have little resistance ever. They move the cylinders to the position of the lever, not like a "up neutral Dowm type lever. I bet it is not primed. Make sure there is fluid in the res, then put 25psi into the reservoir with a tire pump (not 100PSI) and move the valve levers through their motion range for several minutes while at mid RPM. Let us know what is going on. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
