Re: Corroded battery cable
Posted by equeen on June 09, 2011 at 18:58:07 from (209.102.248.55):
In Reply to: Re: Corroded battery cable posted by equeen on June 09, 2011 at 18:54:38:
third party image
Photo taken without flash to get better "picture of green".
The corrosion is around each strand of the wire but does not penetrate into the strands. However, my thinking is that current should go thru and around each strand getting the effect of a large single strand cable.
