Re: Corroded battery cable
Posted by Janicholson on June 09, 2011 at 19:08:51 from (67.72.98.45):
In Reply to: Re: Corroded battery cable posted by equeen on June 09, 2011 at 18:58:07:
The strands must be reduced in cross section to increase its resistance. At low voltage, and high amperage it is section area that counts. If the strands are basically very little smaller, the conductivity will not be off by much. From the look of the inside of the clamp, that could have been substantial resistance there. Poor connection between the strands and the clamp can also be a major resistance. Best of luck.
