Re: Corroded battery cable
Posted by d beatty on June 10, 2011 at 09:38:13 from (67.167.73.6):
In Reply to: Corroded battery cable posted by equeen on June 09, 2011 at 16:38:49:
equeen, Did you clean the battery posts and other cable end. From the picture the posts & other cable needed a lot of cleaning.Did you try cleaning all termanals on gen.& regulater?
How old is the battery? Old battery sometimes get to the point that they will not take a full charge.
