Bat born Feb 2011. Cleaned with drill-mounted wire wheel reg & gen terminals/posts and grounding areas on reg and gen.
Replaced both cable ends to battery posts with shiny new ones and thoroughly cleaned battery posts and cable wires to cable ends before replacing with new cable ends.
Finally, went to IH and purchased a new 7' cable and installed it. No change. Still cranks fast and smooth - but no charging of battery.
Recharge battery with typical battery charger when it drains. Charges back up to 6.25-6.30 volts across posts.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
