Re: 300 rear main seal
Posted by David G on June 12, 2011 at 07:22:01 from (72.100.54.121):
In Reply to: 300 rear main seal posted by chrism in tn on June 11, 2011 at 18:53:41:
Make sure and clean up all the metal surfaces good with brake clean, then wipe them dry. I put a little dab of permatex sealers in the square corners where gaskets meet. I also glue the gasket to the pan before installation so it stays aligned. There are a bunch of small gaskets so make sure you get all of them ordered.
